跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
797 个问题 查看全部
Lagging iPod 5th Generation
Hey guys,
My iPod 5th Generation lags when I play certain songs. I’ve tried already a lot of possiblities: first deleting only this album, uploading it again, but the same. Then restoring the iPod through iTunes, then I upload again three albums and already at the 5th song starts to lag.
At this point I can feel while holding in my hand that the hard drive is lagging too. I can escape of this only with the two button reset. After that everything is fine again till I get to one song where it starts to lag again.
How could I solve this problem? Do I need to change the hard drive, or there is other possibilities?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
which iPod 5 is this? sounds like the original...
完成的
iPod 5th G. 60gb Serial No : 8K632DWKWEF
完成的
添加一条评论
1个答案
已选择的解决方案
I think you are correct that it is the HDD, the iPod is several years old and has likely played a fair few tunes in its time. You will need to find a new HDD and follow this guide
iPod 5th Generation (Video) Hard Drive Replacement
read the guide a few times, take your time and it should be fine.
这个答案有帮助吗?
得分 4
1条评论:
Mine went a few years ago ended up putting in a SSD unit Tarkan iFlash-Dual SD Card Adapter For iPod 5 Generation and Later best upgrade I could have done!
完成的
添加一条评论
添加你的答案
Tamas David 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 345
