跳转到主内容
加入维修社区 - 创建账户
2015年三月发布的MacBook 11吋使用第五代intel i5/i7处理器,並且拥有比前代稍佳的性能与电池寿命。
System can't detect drive, all I'm getting is blinking question mark
How to fix blinking question mark in MacBook Air 11”?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If you see a question mark folder is that the Mac don’t find the MacOS.You can try this : Power off the Mac than power on and hold the keys Comand + R and the Mac will boot in to the recovery partition.From there you can go to disk utility and run a disk utility in that SSD to check for errors.If you don’t find any errors from that partition you can try to reinstall the MacOS and see if that can fix the problem.
Another option is that you remove the ssd from the Mac put on a external enclosure en boot from the external enclosure using command (option key) and see if you can see the drive or if you can boot.I have seen MacBook Air ssd damage ramdonly so I suggest you to check if that drive is good first :)
这个答案有帮助吗?
得分 1
4条评论:
@gadgetboxrd - This system uses a custom blade SSD so taking it out wont help here.
Instead I would restart the system in target disk mode and then connect the system to another Mac, Or create a bootable OS installer thumb drive from another Mac to then boot up this system. If the onboard recovery partition won't boot or recover the OS.
How to use target disk mode to move files to another computer
Mac startup key combinations
How to create a bootable macOS Sierra installer drive
Lastly, it may just need a new SSD MacBook Air 11" Early 2015 SSD Replacement
完成的
You can boot with a external enclosure that SSD to see if works correct if the drive is encrypted you won't but if is not you can.You can use your recovery partition to install the MacOS but if you have a usb drive you can created a bootable MacOS using terminal or DiskmakerX @danj But like I did mention before if you go to the recovery partition and run a Disk Utility first to see if it show any issues that's the first step i will suggest.Cheers!
完成的
OWC Envoy Pro enclosure
完成的
Thats correct @mayer OWC is the best choice :)
完成的
添加一条评论
添加你的答案
george rhythmasia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 188
