跳转到主内容
7.9寸显示屏/型号A1455 /黑色或白色/发布/ 2012年10月23日/ 16/32或64 GB容量
20 个问题 查看全部
Ipad mini gold pins/pad on logic board missing
Hi, my ipad mini gold plate for touch connector on logic board got missing. how to fix it? thanks
Edited: my ipad mini gold pins on logic board missing
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
I'm not sure I understand the question. "Gold plate"? This is the touch connector being lifted off the motherboard. Which part are you talking about?
https://d3nevzfk7ii3be.cloudfront.net/ig...
完成的
@secondlife sorry sir my bad. i mean this part
完成的
Nothing shows at the address you provided, but you can add a picture to your question following these easy steps: 在已经存在的问题里加入图片
However, if that part in question is a connector on the logic board side it will need to be soldered back in place with proper soldering tools.
完成的
完成的
添加一条评论
2个答案
已选择的解决方案
IPad mini digitizer connector gets damaged from unplugging the screen by grabbing the long side of the connector. Grab it by the short side and you’ll never have this problem.
once the connector is damaged, it is a straightforward job for mail in logic board repair or your local microsolderer. It is not a beginner job.
once the pads are gone then it is a complex job that is quite challenging, but still doable for experienced microsolderers—although perhaps only for data recovery
这个答案有帮助吗?
得分 1
1条评论:
this is what i want to know. so i just need to find someone that can do microsoldering. thanks for your answer
完成的
添加一条评论
最有帮助的答案
Are you talking about the gold pins on the digitizer FPC connector on the logic board? If yes these are fragile and can pretty much break if you are unlucky.
You’ll need to replace that connector through micro-soldering if it is damaged.
这个答案有帮助吗?
得分 1
3条评论:
yes sir, i think it’s a gold pins. this is the sample
完成的
Oh, if it's also the solder pads that have been ripped then jumper wires need to be used to connect the digitizer pins that have missing solder pads under them to make the connection.
完成的
it’s look difficult for beginner like me.
anyway thanks for your answer sir
完成的
添加一条评论
添加你的答案
debab 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 646
