跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
707 个问题 查看全部
Can a BSOD Switch console charge?
Have a Switch console here that has a blue screen no matter what I do, tried a hard reset, tried connecting to a PC to use RCM and diagnose it that way, it just won't do anything other than show me a nice blue screen.
My question is, will the console charge in this state? My thinking is that it needs to be able to boot to get to the point where it can enable charging but right now, it just isn't at all. I only get the blue screen when its plugged in, when I unplug it the console dies.
I've checked the internal battery and it's completely dead. While connected to USB it does show 4.16v getting to the battery, I've not checked the current though.
Basically it seems like it is charging but the battery being totally flat has now died. I'm not sure if it's really worth replacing the battery as it has a blue screen, but maybe the blue screen is a result of the dead battery?
USB port and the charge related ICs seem to be behaving normally.
I should add none of the ingress indicators have activated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Hi!
As far as I know the Switch won't take a charge if the battery runs flat unless you do the following:
1. Power the console completely off
2. Plug it in. It will turn on, wait for it to get to that blue screen of yours
3. Hold down the power button for 20s (I think, could be longer or even shorter), it will force a shutdown.
4. Leave it plugged in for a while, it will charge in this state.
这个答案有帮助吗?
得分 2
添加一条评论
I have the same problem. It has a blue screen. But when I plug in the USB type-c it turns on still in the blue screen but it charges. I bought it like this off of eBay for $75.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
joelwhybrow 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 3,081
