跳转到主内容
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1698 个问题 查看全部
No fresh food cooling?
I have a Frigidaire Electrolux Side by Side FRS26KR4CW1. The Fresh Food box is not getting below 50 degrees F. I went through the manual defrost regimen and there is no change. The freezer fan motor seems to be surging up and down in speed and little cold air pressure can be felt at the damper in the fresh food side. Any Ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Damper Control Assembly
The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won’t let enough cold air into the refrigerator...
Here’s the part:
https://www.repairclinic.com/PartDetail/...
Here’s a video on how to replace it:
https://www.repairclinic.com/RepairHelp/...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Florida Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 36
