跳转到主内容
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Why can't I restore my iPhone with Itunes
When I attempted to restore my Iphone3gs using Itunes on my Toshiba PC the Iphone screen displayed the Apple Logo and the status bar, Itunes said it was preparing the software to restore my Iphone but after more than an hour nothing happaened.
I disconected my Iphone, restarted Itunes and reconnected my phone. Nothing happened.
What do I do noe?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Google DFU mode and how to put your phone into that mode. Then try to install the firmware while phone is in DFU, see if that works.
完成的
添加一条评论
2个答案
已选择的解决方案
Check the dock for dirt/debris , charge your phone at the wall for 1 hour and then try again. You may not have enough power on pc port to power the iPhone through restore. Try different port or powered hub
这个答案有帮助吗?
得分 3
添加一条评论
Did you backup your iPhone with iTunes before ? To begin to restore your iPhone data from the backup, connect your iPhone to the computer that you normally sync it to that contains the backup file (in most cases, this will be your normal computer. If you’re syncing to more than one machine, you should have backups on both computers. Just choose the computer with the backup you prefer).
In the center of the iPhone management screen, you'll see a "Restore" button. Click that.
When you do this, iTunes will show you a few introductory screens. After them, you’ll need to agree to the standard iPhone software license. Do so and click Continue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kimball 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,441
