跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
trouble with home button
Hi,
I've brought a used iPhone 3gs 16gb with broken home button, or I thought so.
I alreday had an other 3gs, so when I changed the entire display assemply of the broken with the one working. It worked great.
I was hundred precent sure it was the home-flex/button. so I orded one from the site. I changed it, but the home button is still not functioning. the iphone is still good when I put the display assembly from the other one into it.
So where to look for the problem :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
does the "broken" home display work in the other iphone?
完成的
no, the problem is somewhere in the display assembly, but where, I don't know
I've also changed the digitizer to a new one :(, so I do want to throw it away
完成的
添加一条评论
1个答案
已选择的解决方案
disassemble the digitiser and home button. clean where the home button sits in the midframe and the back of the home button. as the digitiser plays no part in the home button action I can only imagine that it is installed incorrectly on top of the home button. (ie the digitiser has no electrical contacts with home button) you may also like to check that the 2 gold prongs on the bottom of the home button haven't been flattened... they need to be about 45 degrees to make contact with top of dock.
这个答案有帮助吗?
得分 4
1条评论:
done, no changes, now I've also destroyed the working iphone, something is wrong in the midframe.
it doesn't register any sim-card, saying no sim installed :(
完成的
添加一条评论
添加你的答案
Sami420 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 1,352
