跳转到主内容
Repair guides and support information for televisions manufactured by RCA.
181 个问题 查看全部
My RCA 65 inch smart TV doesn't show an image anymore
Hello i have a RCA 65’’ smart LED LCD TV 1080p SL65A55-A201083. It was working fine then it would only come on after several attempts. Now there is no picture but there is a red light on the bottom. I have tried holding the power button tried the reseting the tv with the power and volume button so far nothing works. I do have voltage at the board. Can anyone help me with this problem? This is the second site i have asked this question and no help at all. wow. Thank you for your response. I have checked those things but everything looks good. Im also not sure which board is which. Could you tell me which board is the power board and were i might be able to order it and which number would i use on the board when ordering it. Thank you so much for your help.
Hi i checked both fuses and they are good. There is 5 volts coming out of the board going to the other board. Also the other board with the hdmi rca connectors on it there is also 5 volts coming in the board and 5 volts in other places on that board. The red light stays on continuously even when you press the power button. I checked the power at the power button and it has that 2 volt continuous and when you press it it goes to zero. Hope this is helpful and here are a few more pics.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
How much does a cxd4737gb cost, and have the same problem 65" Sony flat screen TV could that be the problem
完成的
Hello I’m having an issue with my RCA sld65a55gq can someone help me please?? I turn the tv on and there’s no picture. The back lights come on but nothing. I can see the blank screen.
完成的
添加一条评论
1个答案
已选择的解决方案
@vadertaz this “then it would only come on after several attempts. Now there is no picture” sounds like a bad power board. Remove the back of your TV and take a look at all the boards. Check for obviously damaged components like leaking, domed looking capacitors etc. Post some images of your boards etc. with your question. That way we can see what you see. 在已经存在的问题里加入图片
Update (12/20/2018)
Your power supply board is the one I would start with. Check the fuses for continuity and after that for power to make sure your board powers up.
这个答案有帮助吗?
得分 3
7条评论:
I put some pictures of the board on my comments but i'm not sure which board is which can you advise please.
完成的
完成的
Thank you for all your help. I added some more pics and another comment.
完成的
Hi i put a new power board on and it is still doing the same thing. The red stand by light stays on and there is no picture or sound.There is voltage still going to the main board. I guess ill try replacing the main board. Could the small board that has the power button and volume button cause this kind of problem?
完成的
@vadertaz since you now already changed the power supply, go ahead and try a new mainboard. Unlikely that the error comes from the button board
完成的
显示更多的2条评论
添加一条评论
添加你的答案
John CHAFTON 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 40
总计 14,286
