跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Why is my dead iPhone 5 still not charging?
My phone usually dies after a short while of usage, but yesterday it lasted longer than normal, and said it was at 93% the entire day, until my last period class. I used it all that period because the class was art and I needed a reference photo for my project. All was going fine until it suddenly shut down. This was normal for my phone, so I didn’t stress about it too much. Then I got home, plugged it in, and went to work on something else. When I came back, about an hour later, and tried to turn it on, then all that would show up on the black screen was a battery with a slim red bar on the left side. I thought it was the cord or the plug (even though I had used this cord and plug several times before) and so plugged it into a different cord and plug. This repeated about two more times before I tried plugging it into the computer, and then into a portable charger, but nothing worked! What could be up with my Phone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It might very well be your battery needs replacement, iPhones do not normally shut down at random. If you noticed the phone turning off when opening camera, or as soon as screen was awaken after idle, that’s because battery is not anymore able to supply the peak power these tasks normally require. Unreliable battery readings are another sign of a deteriorated battery.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Ginger 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 82
