跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
645 个问题 查看全部
问题已关闭
Battery will not charge. Magsafe board replaced. What now?
I have a macbook which works fine while running from the battery but doesnt receive any power from the pw supply. The led didnt light up either. I replaced the magsafe board and now the pw supply led blinks a steady green but still wont power the macbook. What do i do now? New motherboard?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Check your MagSafe tip for power using a multimeter. The pinout is on the right in this Wiki: http://en.wikipedia.org/wiki/MagSafe
这个答案有帮助吗?
得分 4
3条评论:
i have two mag power supplies and their both tested as working.
完成的
Is it charging the battery?
完成的
nope.. the laptop wont even turn on. It was running fine when there was still battery power.
I just bought it used and now that the batterys run out, need to recharge and the power supply doesnt work. One of the power supply is from another mac and its practically new. Ive changed the magboard and now the light is blinking steady green.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,758
