跳转到主内容
问题已关闭
Will not boot after hard drive upgrade
The microphone port on the motherboard snapped as I upgraded the hard drive. I closed up and tested the Powerbook afterwards, no boot, no chime, nothing. Everything else is as it was.
Is this socket essential to the notebook?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
I would take out the keyboard and double check that the plugs going from the topcase to the logic board are fully seated and that none of the pins have been missed. It's possible to press the larger main plug down in the wrong position such that only some of the pins are actually plugged into it, in which case it would make sense that nothing happens when you press the power button.
这个答案有帮助吗?
得分 2
1条评论:
Thanks, I'll have another look at the connections.
完成的
添加一条评论
the microphone connector should have no effect on whether the computer boots or not.
have you double checked all connections?
这个答案有帮助吗?
得分 1
添加一条评论
Reinstall the driver (located in logic board CD system driver of that device because some driver and setting are lost in upgrading. (Might be OS in not fully Plug&Play system)
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 1,599
