跳转到主内容
加入维修社区 - 创建账户
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
How can I replace logic board?
Computer will not charge. Apple genius said it needs a logic board replacement. They do not do these older models. Where do I get part and how do I install it? It is a 17" Aluminum PowerBook 661-2823. M8793LL/A
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Barbara, first I'm often suspicious about Apple diagnosis when it comes to a logic board replacement (did they even opened the machine ?). Your problem could also be a faulty DC in board but it can only be tested with a known working part and it's not a cheap part. iFixit sells it for $79.95 so if the problem is really the logic board you could be stuck with an extra DC in board. If you buy the logic board and the culprit is the DC in board then you're in the same situation. You can buy a used logic board on eBay for your 1Ghz machine for $199:
http://cgi.ebay.com/Powerbook-17-inch-G4...
and the DC in board from iFixit here (currently out of stock but call them):
[关联产品丢失或禁用: IF155-008]
Ifixit it repair guide:
PowerBook G4 Aluminum 17" 1-1.67 GHz
Cannot give a better answer without testing the machine.
这个答案有帮助吗?
得分 3
1条评论:
+ I agree lemerise. I see far to many logic boards condemned by uncaring supposed technicians. Please give us the symptoms your machine is having and maybe we can discover a more studied solution. You came to the right place.
完成的
添加一条评论
添加你的答案
Barbara M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 958
