跳转到主内容
Repair guides and support for hair irons, also known as hair straighteners.
How can I fix a short in the wire?
I have a Linea pro flat iron with the pants clip. There's a short in the wire and I have no idea where to get it fixed.
Update (04/01/2019)
How could I fix one myself. No wires are exposed. I could take a picture
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I believe it is where the wire connects. It can swivel and I think it's there. It's a old Linea pro leopard print.
完成的
添加一条评论
2个答案
已选择的解决方案
See if either one of these guides will give you a clue as to how to open it up to check it for burned components. Use a multimeter to test it for continuity to find the problem.
CHI Original Circuit Board Replacement
Hot Tools HPK12 Cord Replacement
Hot Tools HPK12 Cord图片
指南
难度:
简单
10 minutes
CHI Original Circuit Board图片
指南
难度:
困难
1 - 2 hours
这个答案有帮助吗?
得分 3
添加一条评论
hello Sora, if you fix it your self it would be cheaper on you. For a shop to fix you would want to compare cost of product to repair cost. Most likely the short would be at the point of where the wire comes into the main unit being pulled out or to short in wire length overall.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sora Kururugi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,018
