跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1234 个问题 查看全部
Which component is responsible for connecting to the mobile network?
My iPhone 5c recently started intermittently displaying “No connection” in the top left. Resetting the phone would get it to work again. But starting from this morning, no amount of resetting or re-setting network settings has fixed it. Now that I’ve done “reset network settings”, it is stuck at “Searching…” as opposed to “No connection.”
So which component is the “mobile antenna”? Is it replacable? What connections can I clean or jiggle to ensure everything is solid?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Let's rule out hardware first as it's a common cause of the stuck on searching and no service problem.
Dial *#06# in the dialer and a 15 digit IMEI number should be displayed. If not there is a hardware fault relating to the baseband chip or circuit for it.
Check in settings > general > about phone for listed IMEI and modem firmware. If either fields are blank it's the same reason as above with hardware fault.
If it does end up being a baseband hardware fault it'll be too expensive to be fixed in my opinion. These types of board repairs can go upwards in the cost of $100 or more which is close to the cost of buying the same phone second hand.
这个答案有帮助吗?
得分 6
3条评论:
Thank you. Well bad news, I dialed *#06# and each time I press the call button, it darkens momentarily in response to being pressed, but nothing else changes on the screen. I guess this phone is a lost cause. I've done a hard reset but not a full software restore. Is it worth it? I'll probably try soon.
完成的
Oh I have reset network settings, and since then, in Settings, General, About, the "Carrier" is listed as Telstra 28.4. Is there any way it can get that info outside of the mobile connection? Eg. from Wireless connection, or the SIM card?
完成的
A full software restore may help but it may fail the restore with error -9 or -1 due to the baseband hardware fault.
完成的
添加一条评论
Hundreds of components are responsible for mobile connection. This is highly unlikely to be antenna issue as the iPhone uses 2 antennas to connect to mobile network since iPhone 4s.
Mad you said the display IMEI trick sometimes results in phone not responding. This is more likely to be baseband issue, which is a board level issue and difficult to fix.
这个答案有帮助吗?
得分 2
添加一条评论
To rule out software, a full restore and set up as new to test connection will help to tell you definitively if it’s sn issue with the hardware. If it’s still searching after that.
To rule out SIM card - test the sim in another device (if you have access to one). Or try a new SIM card (you can get one at an Apple Retail Store or carrier store) and try to activate it.
If you want to open the device and test connections there, you can re-seat the coax cable that connects to the logic board. Sadly you can’t replace an antenna as it is built into the plastic enclosure of the device.
这个答案有帮助吗?
得分 1
3条评论:
Cellular antenna actually _can_ be replaced, it's part of the lightning connector assembly and extends to 2 further small modules laying on the lightning assembly. You can see main part at step 33 of this guide, however, from the issue described, it's probably to be ruled out as a faulty antenna issue
iPhone 5c Lightning Connector Assembly Replacement
完成的
Thanks Bonnie. I can confirm the SIM card works in another phone as I'm now using it as a backup. I'm going to re-seat the coax cable, thank you. I'll also do a full restore.
完成的
Hello, I have a similar issue now on my iPhone 11pro, it says no service and also gets stuck on searching sometimes. Were you able to fix yours?
完成的
添加一条评论
添加你的答案
domarius 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 77
总计 1,109
