跳转到主内容
Repair information and support for GE Profile Refrigerators.
60 个问题 查看全部
The water filter is leaking
The GE refrigerator is 2 years old. I’m in this house for about 1 year now and I replaced the filter once already. After 6 months, the water filter light came on again, and so I bought from GEappliances online a set of three new water filters MWF exactly the same as the one being replaced. The instructions says something about align the arrows and turn to the right until it stops. The arrow in the filter doesn’t have another mark to align to, but I managed to fit it in and twist to the right until it sops. However, it immediately started to leak. I took it out and try again, still leaking. Try for a third time, completely out and then in again twist it until it seemed it fits and turning more until it click and then it stops….still leaking. What’s the problem? I bought it as a genuine part from GE directly.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
I’d replace the water filter head like this":
https://www.youtube.com/watch?v=AvHpBn9p...
这个答案有帮助吗?
得分 2
添加一条评论
Look at O ring and inspect it for wear/tear and b sure to note that it properly sits between filter and housing. If problem still persist be sure to contact manufactur for potential recall on manifold.
这个答案有帮助吗?
得分 1
添加一条评论
My GE inline water filter developed two pinhole leaks along one of the seams after two years of use. Woke up to the sound of floor tiles popping apart from their adehsive.
这个答案有帮助吗?
得分 0
添加一条评论
First, ensure the filter is genuine and not defective. Even genuine parts can sometimes have faults. If the filter is fine, the problem could be with the refrigerator's filter housing. It's possible that the seals or connections in the housing are worn or damaged, which can cause leaks when a new filter is installed.
I recommend checking the housing for any visible damage. If everything looks intact, you might want to contact GE customer support for further assistance, as they can provide more specific guidance for their models.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cesar 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 62
过去 30 天: 295
总计 18,433
