跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1202 个问题 查看全部
The Phone will not activate!
Hey All
ok i have an iPhone X and i restored the the phone to 12.1
since then i can not activate the phone.
Find my iPhone has been switch off before i don’t the restore its off on the system and its unlock to any network.
i have Dfu restored also with recovery on countable times
when i connect to wifi to active i get the error
“Your Phone could not be activated because the activation several is temporary down”
connect throw iTunes i get the error
“THE iPhone could not be activated because the activation information could not be obtained from the device.
i have tried other sim cards, it shows they get signal in top corner.
the phone was working with the sim card i used before.
Anyone know a way around it?
it just won’t activate
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
So, you are saying it works with other SIM cards but won’t work with a particular card? That tells me that the particular card that’s not working has failed. Get a new SIM card and it should be fine.
这个答案有帮助吗?
得分 0
4条评论:
no bro, it doesn’t activate with no sim card.
the phone will not activate.
完成的
"i have tried other sim cards, it shows they get signal in top corner'." What is that about then?
完成的
I have the same problem. I get a signal in the top right corner of the screen. I called my carrier and activated a new Sim card and I'm still getting the same error message
完成的
Try to dial *#06# and see if the device returns its IMEI.
完成的
添加一条评论
I’m having the exact same problem, please help :(
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Blanco 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 559
