跳转到主内容
加入维修社区 - 创建账户
GoPro’s seventh generation camera released in late 2012. Capable of recording 1080p30 video, waterproof to 197', and built-in Wi-Fi.
Why does my hero3 silver freeze up?
How do I know if the mother board is bad in my Hero3 Silver?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
I was actually talkjng about the root software the board was loaded with initially.
完成的
Your best bet is the guide I gave you in my answer. It's not the root software but it is the OS. It's the best I could find, sorry!
完成的
添加一条评论
3个答案
最有帮助的答案
We can determine if it’s a software problem or not if we factory reset your camera. If it’s a software problem it should be fixed by a factory reset. Factory resetting your camera will reset all settings you have configured!However, if you remove the SD card from the camera before doing a factory reset your videos and pictures on the SD card will be safe.
  • While The GoPro is off, press and hold down the shutter button (the top button).
  • While still holding the shutter button, press the power button (on the front of the camera).
  • The camera will now power on and it will reset to the original settings.
这个答案有帮助吗?
得分 4
1条评论:
This does nothing. If I remove the battery hold the power button for a minute then reinsert battery it powers on and will work temporarily.
完成的
添加一条评论
Looks like a factory reset didn’t help, nor was the storage full. I think your motherboard may be indeed kaput. Replacing it should get you back into business.
GoPro Hero 3 Silver Motherboard Replacement
GoPro Hero3 Silver Motherboard
Update (11/20/2018)
You can try to follow this guide to update the software, which may solve your problem. I think there’s more then a software issue going on here, though.
Replace the main circuit board assembly for the Silver Edition of the GoPro Hero3.图片
产品
$19.99
这个答案有帮助吗?
得分 2
4条评论:
well that kind of sucks
完成的
I can get it to power on and take a picture or two or a video but then it locks up again. I finally got it to finish the up grade to 3.02.
完成的
Is it possible to reload the firmware on the camera?
完成的
@jasonclayton If a factory reset doesn't do anything to help there's likely a board level issue going on here. Replacing the motherboard is fairly inexpensive and will very likely solve your problem.
完成的
添加一条评论
the storage might actually be full or something and it doesn’t want to work. try deleting some stuff on the storage.
这个答案有帮助吗?
得分 1
1条评论:
Card is empty.
完成的
添加一条评论
添加你的答案
Jason Clayton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 34
总计 2,689
