跳转到主内容
加入维修社区 - 创建账户
GoPro Hero 3 Silver Motherboard Replacement
你所需要的
    1. GoPro Hero 3 Silver Motherboard Replacement, Battery: 步骤 1 中的图像 1,2 GoPro Hero 3 Silver Motherboard Replacement, Battery: 步骤 1 中的图像 2,2
      • Pull back on the tab on the back of GoPro to open the battery cover.
      询问修复机器人
      添加评论
    2. GoPro Hero 3 Silver Motherboard Replacement: 步骤 2 中的图像 1,1
      • Pull the battery out using the tab.
      询问修复机器人
      添加评论
    1. GoPro Hero 3 Silver Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,2 GoPro Hero 3 Silver Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,2
      • Use the plastic opening tool to remove the faceplate.
      • There is some adhesive and clips so be careful and the faceplate should pop right off.
      询问修复机器人
      添加评论
    2. GoPro Hero 3 Silver Motherboard Replacement: 步骤 4 中的图像 1,2 GoPro Hero 3 Silver Motherboard Replacement: 步骤 4 中的图像 2,2
      • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
      • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
      询问修复机器人
      添加评论
    3. GoPro Hero 3 Silver Motherboard Replacement: 步骤 5 中的图像 1,2 GoPro Hero 3 Silver Motherboard Replacement: 步骤 5 中的图像 2,2
      • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
      • Using the plastic opening tool, slowly pry open the motherboard assembly.
      询问修复机器人
      添加评论
    4. GoPro Hero 3 Silver Motherboard Replacement: 步骤 6 中的图像 1,2 GoPro Hero 3 Silver Motherboard Replacement: 步骤 6 中的图像 2,2
      • Use the spudger to gently pry off the connector of the housing to the motherboard.
      • You should now have the motherboard assembly and the housing separated.
      询问修复机器人
      添加评论
    5. GoPro Hero 3 Silver Motherboard Replacement: 步骤 7 中的图像 1,3 GoPro Hero 3 Silver Motherboard Replacement: 步骤 7 中的图像 2,3 GoPro Hero 3 Silver Motherboard Replacement: 步骤 7 中的图像 3,3
      • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
      • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
      • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
      添加评论
    6. GoPro Hero 3 Silver Motherboard Replacement: 步骤 8 中的图像 1,3 GoPro Hero 3 Silver Motherboard Replacement: 步骤 8 中的图像 2,3 GoPro Hero 3 Silver Motherboard Replacement: 步骤 8 中的图像 3,3
      • The media adapter is attached to the motherboard via 3 screws:
      • x1 T4 Torx
      • x2 Phillips #00
      • There's a little silver bracket that is held down by the Phillips #00 screw so be careful not to lose it.
      • With a little prying, use the spudger to detach the media adapter's connector from the motherboard.
      询问修复机器人
      添加评论
    7. GoPro Hero 3 Silver Motherboard Replacement: 步骤 9 中的图像 1,3 GoPro Hero 3 Silver Motherboard Replacement: 步骤 9 中的图像 2,3 GoPro Hero 3 Silver Motherboard Replacement: 步骤 9 中的图像 3,3
      • Use the spudger to lift the black tab up to unlock.
      • Then remove LCD screen connector by sliding out.
      询问修复机器人
      添加评论
    8. GoPro Hero 3 Silver Motherboard Replacement: 步骤 10 中的图像 1,3 GoPro Hero 3 Silver Motherboard Replacement: 步骤 10 中的图像 2,3 GoPro Hero 3 Silver Motherboard Replacement: 步骤 10 中的图像 3,3
      • Using the Phillips head bit, remove the silver screw near the top edge of the board.
      • Separate the LCD assembly by pulling it away. You should have the bare motherboard!
      添加评论
结论
取消:我没有完成这个指南。
16等其他人完成本指南。
Brian Alvarez
于04/02/15注册
1,439 声望
创作了6篇指南
团队
Cal Poly, Team 24-7, Lancaster Spring 2015 Cal Poly, Team 24-7, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S24G7
3 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 51
总计 9,258
