跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 个问题 查看全部
Xbox one S turns on then off.
Xbox beeps, lights up then shuts off.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
5条评论
How do I check the Power Supply?
完成的
well how do I know if its the Power Supply or something else?
完成的
@daveparker Its usually a failing power supply when an Xbox shuts off moments after being turned on. The only other thing besides a (inexpensive) PSU replacement is a board level issue.
完成的
Im having the same issue. Ive tested all mosfets and seem ok. No short on any of the 12v rails, yet showing short on nearly every cap after mosfets. Assuming the APU is dead and has shorted internaly. Will test with another psu and get back.
完成的
添加一条评论
4个答案
最有帮助的答案
We get people asking about their Xbox powering off 1-5 seconds here all the time. It’s almost always the PSU that has gone bad. Replacing the PSU should help.
Xbox One S Power Supply
Xbox One S Power Block Replacement
Xbox One S Power Supply图片
产品
$29.99
这个答案有帮助吗?
得分 2
4条评论:
Why was this answer made a comment?
完成的
Because it is more of a guess than an answer. At least you could get the OP to test the PSU before suggesting to replace it. Sometime things can be fixed and must not always be replaced. That is why this place is called iFixit not iReplace it.
Chalk it up as shortsightedness and a mistake on my part since your answers are always outstanding. Have a Happy Thanksgiving !
完成的
@oldturkey03 I have never used a multimeter so I couldn't really assist with testing of the PSU. Happy Thanksgiving to you too!
完成的
添加一条评论
Try using a blow dryer on the top vent for a bit, then try turning it back on. Found that fix on another website.
这个答案有帮助吗?
得分 0
2条评论:
I bought a new power supply, installed it but my Xbox one s, still turns on then 5 seconds turns back off. Anybody have good answers in what else it could be.
完成的
Do you have any solution? I have the same problem, still turns on then 5 seconds turns back off
完成的
添加一条评论
I can’t use my controller to turn it on when I try to hold the power button but that does not work I looked on YouTube but that did not work
这个答案有帮助吗?
得分 0
添加一条评论
Usually the problem occurs when water reaches the fans or the psu (power supply) or it overheats because of the safety lock that occurs when a lot of dust is in the fan, but the most common case is when the psu is faulty or isn’t plugged in properly. Try unplugging it then plugging it back in or try replacing the psu. If it still doesn’t work replace the fans that has a high chance of working. If you tried all this and it still didn’t work contact Microsoft. I had the same problem myself. Hope This Helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
xxGamerMLGxz 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 42
总计 18,373
