跳转到主内容
The HP Officejet 4630 is a wireless color inkjet all-in-one printer.
14 个问题 查看全部
Ink cartridge failure help
I have a HP 4630 OfficeJet Printer. I have a new HP 61 black ink cartridge that I ordered from HP. I put it in the printer, and it continually says, " Ink Cartridge Failure". I have done all I know to do, reset the printer, cleaned the contacts, etc. I have been on HP.com and nothing works. It is out warranty, so you can only access information on HP.com for tech help. Does anyone know anything to help me with this problem?
Here is other messages that shows on the printer
1. Ink Cartridge(s) Problem The following Ink Cartridges must be replaced. I have brand new ink cartridges.
2. It was printing about 2 weeks ago, when I replaced the empty ink cartridge. Then, it stopped. I called HP and they sent another one. Now, it will not accept the new cartridge.
3. I have downloaded print drivers from HP.com and I have uninstalled and reinstalled the printer software about 4x.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Mine prints but nothing is printed out on my paper? THe ink cartridge indicator shows over 1/2 full?
完成的
Mine won't accept genuine HP cartridges. Says incompatible cartridge (new black). HP Support says to clean everything. Did that but same display. HP says to take it in for repairs.
完成的
添加一条评论
3个答案
已选择的解决方案
Whew! I have been at this printer off and on and had tried everything. Lo and behold, today I just took some scotch tape and taped over the bottom of the ink cartridge (The part where the original tape comes when you buy a new one and take it off) and inserted it back into the printer, then I took the tape off and inserted the cartridge back in the printer. All of a sudden the error message "ink cartridge failure" was gone and the control panel on the printer showed and was up ready to print. I can't even explain it. But, it is printing again. Thanks everyone!
这个答案有帮助吗?
得分 5
4条评论:
van you explain this as i am currently having the same problem
完成的
I’m having the same problem
完成的
Didn't fix mine.
完成的
Mine neither. I hate printers
完成的
添加一条评论
can you explain more detailed how you fixed it
这个答案有帮助吗?
得分 0
添加一条评论
I read the comments above, put a tape over the black ink ink part, took it off and put it back, and it didn't work, I then took out my color ink, which the ink part on the color ink had melted, i seldom used the color ink, it was saying I am now on single ink, and it worked! now it's printing!
这个答案有帮助吗?
得分 0
1条评论:
Surprisingly, removing the color ink cartridge, closing the empty location of the printer's color ink "clip" as much as possible, gave me the "printing from single cartridge" comment, it then printed a (blank) alignment page, I scanned it, read "alignment failed" and chose "OK", another attempt, alignment of just black page printed and scanned, and then itprinted fine with just the black ink.
完成的
添加一条评论
添加你的答案
Sonya 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 17
过去 30 天: 69
总计 19,946
