跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
White Screen of Death after Replacing LCD Screen
Hi guys.
I have replaced the LCD screen on my iPhone 8 and after turning on the phone I get a screen with a white background and black apple logo and it is stuck there besides a loop that occurs every few minutes.
I tested the phone again with my old cracked screen and I get the same occurrence so I know it’s not the new LCD screens fault…
I presume this has something to do with some connection with the main phone components? Did i break the mother board? Or does anyone else have any idea on what may have happened and if I could test anything else to see if it works?
Many thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Just to update everyone, in case this happens to anyone else… I damaged the front camera flex cable so that was causing the battery to drain quickly and not allow me to go further that the power up screen.
I can use the phone without the flex cable connected (minus a few working features such as the front camera and speaker), will be replacing this asap.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
There are a lot of small components surrounding the battery and screen connectors. It is possible you damaged or dislodged one of them to cause this issue. Take a close look at that area to see if anything is damaged or missing. Use magnification, something like a jewelers loupe will come in handy.
这个答案有帮助吗?
得分 3
1条评论:
Will have a look at this asap. Thanks a million for your help Minho. I suspect maybe something may be wrong with the battery perhaps as the screen turns on (with the white background and black apple logo) when it is plugged into a power source, but when the iphone is not plugged in, it won't even turn on to the white background, but it will show the 'out of charger, please plug it' graphic on screen when i try and turn it on..
完成的
添加一条评论
Aha, there’s your problem. You need to disconnect the battery before removing the screen otherwise you ruin the screen. You’re in for a screen replacement now, sorry! :-(
iPhone 8 Screen
iPhone 8 屏幕更换
Replace a screen compatible with iPhone 8. Includes all of the small parts preinstalled in the assembly. Features a 4.7 inch 750 x 1334 pixel LCD Display, Front Glass Digitizer Panel, Front Camera Assembly, Earpiece Speaker, LCD Shield Plate.图片
产品
iPhone 8 Screen
$54.99
这个答案有帮助吗?
得分 1
2条评论:
The OP said he tried with the original screen and had the same problem...
完成的
Yeah it mustn't be the LCD screen's problem as I tried with my original screen as the same problem occurs..I reckon it must be something to dothe battery or motherboard connections perhaps
完成的
添加一条评论
添加你的答案
Dylan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 738
