跳转到主内容
The PowerMac G5 is a desktop computer first produced in 2003 by the Apple Corporation. This guide will review the repair process of an Apple PowerMac G5 model number A1047 EMC 2061 from 2004. It was discontinued in 2006 as part of the Intel switch first to developers then consumers.
The overtemp light is coming on...
Can one add additional cooling fans to a PMG5 which is experiencing overtemp conditions??? Will the addition of more fans help to cool the processors???
Suggestions???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Please give us the last three letters of your serial number so we can identify which machine you have. Thanks
完成的
添加一条评论
1个答案
最有帮助的答案
This model of PowerMac G5 is most likely watercooled. In these models, the coolant tends to leak, and spill onto the power supply, and motherboard. The cooling systems also can fail altogether (The pumps can just die). I recommend that you stop using it, and check inside the case for any spilled coolant, or corrosion (Which is a result of spilled coolant) Unfortionatly, this isn't a problem that you can fix yourself, as swapping CPUs/Cooling units will cause the computer to (In most cases) run the fans erraticly. If cooling leakage is the problem, you should take it to an Apple Store. For a while, they were replacing faulty leaking G5's with Mac Pros, but I'm not sure whether they still do that. For more information, look at the first answer of this question.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Arthur Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 919
