跳转到主内容
Why I cant connect to external display?
Hello,
I have this problem at my work with my MacBook Pro 2018.
While connecting to projector with 15m HDMI cable via USB-C hub I get no input on projector, but my Mac finds the projector and I can even change resolution of projector.
Then when I took a shorter cable my Mac suddenly started to mirror display. All windows laptops works perfectly with that projector and most Mac’s do as well.
Tried different USB-Chubs no help, and I had same problem with two different Projectors and two different MacBook Pro’s both the newer 2018 model.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
After booting completely and with the external plugged in hit Command and F1 keys at the same time.
这个答案有帮助吗?
得分 2
1条评论:
Will try it next time I come across Mac
完成的
添加一条评论
I don't have the latest mac, but sometimes they don’t get connected automatically to an external display. If that happen, you should check the section of displays in settings, and select it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Artur Aleksandrov 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 226
