跳转到主内容
Televisions made by the Chinese multinational electronics company, TCL.
264 个问题 查看全部
Volume fluctuates on TCL TV
I have a 4K TCL SmartTV and I’ve noticed when the scene changes or sometimes just if people are talking the volume drops drastically,to the point I can’t hear anything besides whispers. My TV is connected to a Vizio Soundbar and I can’t figure out how to turn off the volume adjuster on either one.
Thank you for your time
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
Hi,
What is the model number of the TV?
完成的
My tcl roku tv volume increases/decrease automatically. Any solution? TIA!
完成的
Hi @Ushman Ashraf,
Check in the menu > audio settings if there is an AVL (Automatic Volume Level) or similarly named setting.
If there is, try turning it On (or Off) and check if it makes any difference or not.
完成的
I just purchase a TCL Roku TV but when you use you control remote to put the volume up they keep going all the way to a hundred and if you try to put it down they don't let you
完成的
My 65 and 55 inch smart tv, the remote are delay responding when you increase, decrease, ok, left, right up and down button. The battery is new same problem delay responding. Please reply asap, thanks.
完成的
添加一条评论
2个答案
最有帮助的答案
Hey Roberto! Your TV and your soundbar both have audio settings that enhance dialogue. I would make sure that they are both set to enhance dialogue, or totally disable audio on one of them to try and isolate the problem. You could also have a faulty cable connecting the two that is shorting somewhere and causing the volume fluctuations.
Good luck, I hope this helps!
这个答案有帮助吗?
得分 2
添加一条评论
Hi @cachito ,
Don't know your TV but does it do this when you use the Volume buttons on the TV itself (if it has any that is)?
If not then you may have a faulty remote.
If it still does this when using the TV Volume controls then as it is new, either contact the retailer or the manufacturer (see warranty for details) about the problem
这个答案有帮助吗?
得分 1
1条评论:
I had problem of changing channel and volum up and down automaticall I gave it to a repair electronic shop and fix it for me .they said it was control faulty inside tv was problem. Theyvcharged me 185 dollar australian.
完成的
添加一条评论
添加你的答案
Roberto Picos 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 25
总计 8,245
