跳转到主内容
加入维修社区 - 创建账户
External DVD player issue
Hi All
I have an odd problem with my external DVD drive I’m using on my Macbook Air
The mac is reading the presence of a disc but it refuses to play it or read it.
I thought it was the drive, but when I plugged it into my PC it works fine. 100% OK,
Any ideas?
I’m running the latest Mac OS - Mojave
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
@ayyon777 are you using a USB SuperDrive made by Apple?
完成的
Hi Aaron
No it's a 'generic' drive. It's used to work fine. Last used it in the summer and worked OK, suddenly just stopped
the actual message that appears on screen is -
'The Disk you inserted was not readable by this computer'
But it says this with every disk! And when I plug into my PC is fine, no problems
完成的
@ayyon777 It would be nice to have the make and model number of your drive...
完成的
There is nothing on the casing to say who it's made by. It looks exactly like the superdrive but it's a clone. had it for about 5 years always worked fine.
完成的
添加一条评论
1个答案
已选择的解决方案
Setting up a Mac to share discs
To share discs from a Mac that has a built-in or external optical drive, use these steps:
  1. On the Mac that has an optical drive, choose System Preferences from the Apple menu.
  2. Click the Sharing icon in the System Preferences window.
  3. Make sure you've entered a name that you can easily recognize in the Computer Name field.
  4. Enable the checkbox for DVD or CD Sharing.
  5. You can also restrict who has access to your optical drive by selecting "Ask me before allowing others to use my DVD drive."
这个答案有帮助吗?
得分 2
1条评论:
What if there isn't a box for DVD ir CD Sharing?
There are:
Screen Sharing
File Sharing
Printer Sharing
Remote Login
Remote Management
Remote Apple Events
Internet Sharing
Bluetooth Sharing
Content Caching
完成的
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,440
