跳转到主内容
此为等候许久的Mac mini硬件更新。处理器方面支持选配3.6GHz四核i3,3.0GHz六核i5,及3.2GHz六核i7英特尔CPU。
Solder an external power button to the latest mini?
Hi y’all,
Just got the latest Mac mini and I need to add an external power button to it with long wires so I can turn it on and off from a distance. In the previous models I was always able to trace back the wires to the pins and splice the cables but with this ultra flat cable now, anyone knows where I need to add my wires?
Thanks a bunch!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
已选择的解决方案
If you are trying to setup a media server (or other server) you can setup wake on LAN which is what I would do.
这个答案有帮助吗?
得分 3
12条评论:
Thank you @danj , I think I figured it out and I’ll post my result on this forum cause, hey, might be useful for others. This year’s Mac mini’s layout makes it difficult to figure out which pins are the button ones because of the 8-pin flat cable. But I think I found them. I’ll try to turn it on and let you know hehe
完成的
Do keep in mind if you alter the logic board or cable connection you will void your warranty!
完成的
@danj did they get rid of the IR control?
完成的
@mayer yes, they ditched the IR control. There is no more black piece of plastic under the sleep light which is where the IR sensor used to be.
完成的
Sadly, I don't see any sensor window in the IFIXT teardown. Bluetooth or WiFi would be the only way you might be able to turn it on remotely wirelessly. I have mine (2011) setup to wake on LAN.
完成的
显示更多的7条评论
添加一条评论
So what was the solution? You wanted to post it…
这个答案有帮助吗?
得分 0
2条评论:
I’d love to know how to bypass the switch I broke mine. I juts need to get it turned on !
完成的
I also want to know this solution.
完成的
添加一条评论
I created a Mac Mini M1/M2 Holder Vesa Mount with Switchbot and Servo Power Button Pusher you can print to use for this. https://makerworld.com/en/models/1637923
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jess B 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 40
总计 2,494
