跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
What upgrades are possible in this system?
Is it possible to adapt a MacBook Pro mid 2012 logic board (and other parts maybe) in this system?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Sadly Apple's laptops don't have removable chips (thin laptops tend not to). Here's a view of the logic board:
The larger green chip is the CPU
There are two models in the Mid 2012 (2.5 & 2.9 GHz) the only choice here is a logic board swap out if you have the lower end model within the series you could get the upper end model but it’s not enough benefit unless your logic board had died. Likewise, there is no newer logic board possible either as Apple completely redesigned the MacBook Pro in 2012 with the retina series. So upgrading is not possible to anything newer.
But! You do have some areas which you can gain performance!
To start with, I would bump the RAM up to 16 GB.
The next area would be the storage. Here you could swap out the HD with something bigger, I would go with a SSHD from Seagate as the best option here. The other option here is to take the big leap to a SSD. Just make sure you get one that has enough space. After you load it up you want to have 1/3 to 1/4 of the drive free more for the smaller SSD's.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
You can replace the Hard Drive in the MacBook with an SSD to speed up your system in terms of time of booting MacOS up and reduce time taken for loading applications:
2012年中期13寸 MacBook Pro 一体化机更换硬盘
You could use a dual-drive configuration to use a SSD as main drive and Hard Drive as secondary drive combo to have both lots of storage space and a fast loading MacBook:
安装MacBook Pro 13“Unibody 2012款中期双硬盘
You can upgrade the ram capacity of this MacBook to 16GB which iFixit sells 2x 8GB sticks here:
MacBook Pro 13" Unibody 中期 2012 RAM内存条更换。
MacBook Pro 13" Unibody Mid 2012 RAM 内存条图片
指南
难度:
简单
15 - 30 minutes
MacBook Pro 13" Unibody Mid 2012 硬盘图片
指南
难度:
中等
30 - 45 minutes
MacBook Pro 13" Unibody Mid 2012 双硬盘图片
指南
难度:
中等
10 - 30 minutes
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
dany34 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 141
