跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
How to restore iPhone from recovery mode?
how to restore iphone from recovery mode
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
have you tried connecting to itunes and clicking on restore? or are you stuck in bootloop?
完成的
what error itunes giving when trying to restore?
完成的
thnk u so so much
完成的
添加一条评论
6个答案
最有帮助的答案
just plug in the phone via usb cable and try to restore the phone but you must have a internet connection. restore need a software file (version=4.3.3) 660mb that will downloaded automatically . if you are stuck in the loop then remove the back cover and remove the battery plug for 5 mins then restore it .
这个答案有帮助吗?
得分 1
1条评论:
tried that , didn't work
完成的
添加一条评论
can't restore in Itunes receive error message 1015
这个答案有帮助吗?
得分 0
1条评论:
that's a common error for a jailbroken device that apple won't recognise. Google the solutions for either mac or pc-should be straightforward.
完成的
添加一条评论
Connecting to iTunes and click restore will erase all the data and setting on iPhone. If you don't have an available backup to restore from, you'd better not do that. The tool ReiBoot is used to exit iPhone recovery mode with one click, without resetting iPhone and connecting to iTunes. Have a try if needed.
这个答案有帮助吗?
得分 0
添加一条评论
You may try this iPhone Photo Recovery, which allows you to recover photos from iPhone directly, see a guide here:
how to recover deleted photos from iPhone 5
这个答案有帮助吗?
得分 0
添加一条评论
To get iPhone out of recovery mode, I'm afraid you'd turn to some professional software to help you. Or you can simply refer to the guidance here: iPhone Stuck in Recovery Mode & How to Fix
这个答案有帮助吗?
得分 0
添加一条评论
Here is a quick guick on how to fix iPhone stuck in recovery mode:
1. Lauch iTunes (make sure you've installed the latest iTunes).
2. connect iPhone to computer via usb cable.
3. Wait for iTunes to recognize your device. An iTunes popup will display that offers to restore your iPhone using your most recent backup.
4. Click OK to exit restore mode.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
vinothini 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,652
