跳转到主内容
加入维修社区 - 创建账户
The Coolpix P530 is a 16.1 megapixel digital camera with an impressive 42x optical zoom. This model was released by Nikon in February of 2014. It also goes by the manufacturer specific model name Nikon 26464 .
camera nikon coolpix p520 does not turn on
change battery and it does not work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
First check the battery. Is it charged? Is it healthy or old and dead? If the battery is OK take the camera to a service facility; you cannot fix the insides of cameras, unless you are a trained camera technician.
这个答案有帮助吗?
得分 0
1条评论:
Known problem... hundreds have the same problem with this camera... no known solving issue.. looking for an answer all over the internet... Even Nikon doesn't want to fix... new battery, received today... impossible to turn on camera
完成的
添加一条评论
Talked to a Nikon repair guy: his simple answer … “it’s a contact issue” meaning the problem can be most likely solved with a soldering iron, reworking solder points one by one…
这个答案有帮助吗?
得分 0
2条评论:
ma alla fine qualcuno c'è riuscito? non esiste un consiglio decente, accettabile, intelligente, competente, onesto in tutto il web!
完成的
credo invece che il problema sia del software, la macchina va in protezione o per la batteria troppo scarica o peggio per la batteria non originale. in questo caso sarebbe un comportamento profondamente disonesto della Nikon! che non ha mai rilasciato una soluzione che possa essere utilizzata dal cliente finale, il quale deve per forza rivolgersi a quei centri di avvoltoi convenzionati e complici!
完成的
添加一条评论
添加你的答案
henryfiold 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 11
过去 30 天: 29
总计 4,175
