跳转到主内容
加入维修社区 - 创建账户
此为等候许久的Mac mini硬件更新。处理器方面支持选配3.6GHz四核i3,3.0GHz六核i5,及3.2GHz六核i7英特尔CPU。
2018 Mac Mini internal sockets
Does the 2018 Mac Mini have a spare PCIe socket like the 2014 mac mini had; creating the potential to add our own ribbon cable and internal storage?
Update (11/06/2018)
The images in the Apple Keynote only partially show one side of the motherboard and don’t tell the whole story.
Yes, I  understand the onboard SSD’s are soldered to the main board and APFS no longer supports fusion drive, but simply stating points from Apple’s keynote is not the same as confirming what sockets exist on the PCB with a full visual inspection.
A lot of us have spare SSD’s and Mac PCIe ribbon cables laying around.
My first 2018 Mac Mini is on order now. If iFixit doesn’t post a teardown I’ll gladly come back and post my own here and on YouTube in two weeks when it arrives. I have BGA soldering station at work, guess I might as well put it to good use lol, anyone else ever replace a surface mount SSD?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Walk through the Apple Mac Mini overview page If you look carefully you'll see the logic board is mounted with very little room to the upper case similar to how the MacBook Pro is mounted (nothing possible on the other side). The fan and its duct work takes over the space the SATA or PCIe drives had occupied.
Don't get me wrong! I too wished it offered a second drive port. None of the T2 systems as of yet offer a second internal drive port.
One surprise! Mojave does support Fusion Drives now with APFS. Still no RAID support.
As far as replacing the raw flash chips keep in mind Apple uses a custom chips in their iMac Pro and MacBook Pro's. I'm sure they are still using these custom chips here.
完成的
I don’t know, but I don’t have high hopes for that either. Guess we will just have to wait and see what the iFixit teardown finds for us.
完成的
Do you, in general, know how long it takes before iFixit does a teardown on a new product? My Mac Mini is due to arrive mañana.
完成的
添加一条评论
2个答案
最有帮助的答案
Just the RAM is upgradable.
这个答案有帮助吗?
得分 4
2条评论:
@mayer - Correct!
完成的
So you’ve taken one apart already?
完成的
添加一条评论
Sadly no, The images shown in the presentation clearly show there is no storage expansion possibility internally.
这个答案有帮助吗?
得分 1
2条评论:
True, Apple did not say there are any internal storage expansion options; but that doesn’t mean they aren’t there. The 2012 Mac Mini, 2014 Mac Mini and iMac pro were the same way. Nobody knew what internal sockets existed until a full teardown was posted. Just because Apple says the SSDs are surface mounted doesn’t mean there isn’t a port covered up on the mainboard like so many other macs before it.
完成的
Sorry guy no hidden expansion in the 2014 Mini or the iMac Pro.
- The 2012 Mini was known to have two drive support (Fusion Drive) Serviceable RAM
- The iMac Pro has custom flash storage blades. Serviceable RAM
True, the new Mac Mini has serviceable RAM which is standard, Soldered drive storage
No PCIe sockets which is what your question was about.
完成的
添加一条评论
添加你的答案
chad.fraser.nb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 24
总计 3,219
