跳转到主内容
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
62 个问题 查看全部
Why does my ipad have this glitch thingy on the side
my ipad constantly is glitching on the side and i tried to restart my ipad but it wouldnt go away. the ipad still works perfectly and everything but its really annoying because i dont know what it is
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Take a photo of what it is and post it here. We can’t tell from that description.
完成的
misa what is your definition of a "glitch thingy"? What does or does it not do? What does it show on the screen? If you need to post some pictures to show us, use this guide 在已经存在的问题里加入图片
完成的
添加一条评论
1个答案
If you’re describing intermittent touch on one side of the screen, then it is likely due to a bad digitizer. You will need to get the glass digitizer replaced. An easy test is to touch and hold an icon until it shakes, then drag it all over the screen, starting on one side and dragging it the full length up and down from one side to the other. If the icon falls away from your finger, that is the section of the screen that is faulty. Very easy repair and around $100, depending on the model of iPad.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
misa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 71
