跳转到主内容
Released in 2017, the JBL E45BT are wireless on-ear headphones with Bluetooth 4.0 and 40 mm drivers, rated for 16 hours of battery life.
79 个问题 查看全部
Left side of JBL Headphones doesnt work/works again
Hi everyone, my JBL Bluetooth headphones' left side stopped working suddenly. I purchased these 3 months back. Havent dropped them, bent them, etc.
The left side stopped working but then started working again if I gave the headphones a slight tap on the left side of the bridge/ear cup. However, since a few days this solution stopped working too. The other day I was looking for solutions on the internet and a YouTube video had like real bad audio so I had to turn the volume all the way up and VOILA! The left side works again. Now this is happening everytime. The problem exists in both wired/wireless(Bluetooth) modes.
  1. The left side doesn't work initially
  2. I maximize the volume on any loud song.
  3. Left side starts working again albeit a bit slower than the right one.
  4. Repeat 1-2-3
  5. Can anyone tell me what the problem might be and how can it be fixed? Can I do it on my own? I can't really afford to buy new ones so will have to do away with trying to fix these ones. Any help would be highly appreciated. Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
You look to be in a bad spot, it’s probably a broken connector somewhere inside that’s connecting then disconnecting. Maybe if you know how to solder you can open it up like How do I open it up? and see if anything is obviously broken.
这个答案有帮助吗?
得分 0
添加一条评论
I have been having the same problem with my JBL live headphones. Could you tell me what the problem was?
这个答案有帮助吗?
得分 0
添加一条评论
Mine had a loose circuit board. It was easy to fix with a couple of drops of super glue. Just like in this video: https://youtu.be/iTHJBDAdRos
这个答案有帮助吗?
得分 0
添加一条评论
The wire of that left driver is really prone to breakage because its too thin..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Prakeern Gupta 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 46
过去 30 天: 169
总计 16,092
