My dishwasher has water standing in the bottom.
I have checked the drain, there is no garbage disposal. I have checked the drain line and it is clear. I have cleaned all the filters. Replaced the drain pump and turbidity sensor but still water in the bottom. What am I missing? It’s a whirlpool WDF530PLYW7 model
5条评论
Hi @jbailey1978 ,
Place the drain hose into a bucket and run a cycle to check the drain flow pressure.
Also is the drain hose looped up above the main drain pipe connection?
由 jayeff 完成的
How much pressure should there be? And the drain line is looped
由 Janet 完成的
Hi @jbailey1978 ,
Can't give a figure on the actual pressure that should be there. Just so that it appears to come out with some flow to it and not that is seems to be sluggish or impeded
由 jayeff 完成的
Almost no pressure. Barely dripping when it’s set to drain.
由 Janet 完成的
So far no solution. It’s not a new installation but it is a new problem.
由 Janet 完成的
