laptop can't power on
my laptop acer e5 473t when press power button nothing on display cpu fan spins about 2 second and led light turn on and turn off both in 2 seconds immediately , on motherboard don’t have audio - usb cable , may be is it problem ? i tried cmos and ram reset unplug or port and hold power button 30 second but nothing happened
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
@robaka777 you said you tried CMOS reset. How did you do that?
完成的
i could not remove battery , motherboard has battery switcher on or off
完成的
Okay so you never got to the reset? Your computer essentially does not start up into the BIOS or anything
完成的
i think i did everything for reset
完成的
添加一条评论
