跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
20 个问题 查看全部
iPhone 6 plus touch unresponsive
i have a i phone 6 plus with a unresponsive touch i took it to a specialist and he replace the ic chip but after a day with it the touch goes unresponsive again.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Just take it back to the lab where the job was done, if they’re a reputable company they’ll stand behind their work and fix it or refund you the cost they charged you.
这个答案有帮助吗?
得分 3
添加一条评论
iPhone 6 plus series have common issues that only the IC`s replacement is not solution ever,There most me some needs micro jumper too.There M1 point be heated and dry soldering the pin so needs that tutorial may help you. This videos tutorial makes you help.So only changing without this jumper may cause problem after 15-20 days after the replacement of the Touch IC.
这个答案有帮助吗?
得分 1
1条评论:
Please edit your post.
I think that is the same shop the OP took the phone to ><
完成的
添加一条评论
Take it back to the repair center and have them watch this video.
https://www.youtube.com/watch?v=nJu2IVze...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ONLY GOALS 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 68
