跳转到主内容
加入维修社区 - 创建账户
Model A1103 / 1.25, 1.33, 1.42, or 1.5 GHz G4 processor
I cannot eject my Instillation Disk
I was changing Admin Password with the instillation disk inserted, as I was instructed to, but a pop up sheet read “Disk needs to be Cleaned”. Now I can not eject the disk, the “Eject  Leopard Instillation Disk” is showing  in Bold with the Clover Leaf +Q but it is not responding when I press the keys.
My Keyboard is Qwerty so I tried to use the Windows Key on my keyboard  instead of Clover Leaf Command,, unfortunately no response,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Your best bet is to borrow your friend’s keyboard made by Apple and use it to eject your disc. Otherwise you will have to disassemble your Mac mini and manually eject it.
完成的
添加一条评论
2个答案
已选择的解决方案
See if there is a paperclip diameter size hole to the lower right or left of the optical drive slot. If so this is an eject hole, use paper clip in the hole to eject.
That failing, shut it down and restart holding down the mouse.
这个答案有帮助吗?
得分 2
添加一条评论
Does you find power led blinking or not. It shows that your dvd tray stuck. slightly press try in opposite direction and then press eject. Try this few time Or if you find any needle size hole,enter needle inside it to take disk out.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Savlen Dempsley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 24
过去 30 天: 46
总计 442
