跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
563 个问题 查看全部
Trackpad not clicking after some use
The trackpad on my MacBook Pro (13”, 2017, No Touchbar) refuses to register clicks after 30 mins - 1 hour of use. Sometimes I have to press really hard for it to register, and often, as I hold (not press) my finger on the trackpad, it registers as constant clicking.
The MacBook had water spilt on it and the top case was replaced.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
4条评论
a mi me pasa lo mismo ya lo he probado todo lo ultimo reinstalar el ma os y nada la unica forma que hay de que me vuelva a funcionar es la de dejar el mac apagado durante unos minutos, entonces funciona unos miutos y va perdiendo el click poco a poco hasta que deja funcionar la solucion tambien seria remplazar el trackpad?
The same thing happens to me, I have already tried everything last, reinstall the maos and nothing, the only way to make it work again is to leave the mac off for a few minutes, then it works a few minutes and it loses the click little by little until it stops working, would the solution also be to replace the trackpad?
完成的
@Oriol Tinez - Lo siento, sí, también necesitas una nueva unidad de trackpad.
Sorry yes, you also need a new trackpad unit
完成的
okey gracias, pero es original no? porque ya compre un trackpad de otro fabricante olive me parece y me dejo de funcionar hasta el teclado conectandolo y no funcionava el trackpad tuve que volver a poner el antiguo
OK, thanks, but it's original isn't it? Because I already bought a trackpad from another manufacturer Olive I think and it stopped working until the keyboard connecting it and the trackpad did not work I had to put the old one back
完成的
@Oriol Tinez - Lamentablemente, debe utilizar la parte correcta de Apple [关联产品丢失或禁用: IF123-057-3]
Sadly, you need to use the correct Apple part [关联产品丢失或禁用: IF123-057-3]
完成的
添加一条评论
3个答案
已选择的解决方案
You should go back to the place you got it fixed if its still under repair warranty. It sounds like they didn’t replace the Touchpad (trackpad). Unlike older models your’s uses a taptic engine for the feedback of the click. Luckily, the part is very easy to replace! 替换MacBook Pro 13‘’2016末期功能键版本的触摸板. Here’s the part you’ll need [关联产品丢失或禁用: IF123-057-3]
这个答案有帮助吗?
得分 2
添加一条评论
Have you got it fixed? I have the same problem and I have never replaced or damaged anything on my MacBook. The trackpad clicking is great when I turn on the device but after 30 minutes it becomes so firm to click. @danj any ideas?
这个答案有帮助吗?
得分 2
3条评论:
Do you wipe your system with a damp cloth? The cleaner likely seeped into the gaps and into the touch surface sandwich damaging it. These larger Touchpad's are more prone I've replace two so far this year and one person here is also encountering issues as well.
The ones I have fixed all used cleaners often spraying it directly on the system and wiping it off. This offers the window for the cleaner to get where you don't want it! LCD or Trackpad/Touchpad both can get damaged!
I strongly recommend you spray the cloth not the hardware with any cleaner!!
Time for a new Touchpad for you as well...
完成的
Yeah you're right I guess I need to get a new trackpad... Thank you for your help @danj
完成的
Hey, the trackpad was working all winter normally, but started acting up again during summer, so I'm guessing it has to do with the leftover liquid from when I spilled it that condensates at higher temperatures. I definitely have to replace the trackpad.
完成的
添加一条评论
I have exactly the same issue
My guess so far that the battery is what pressing on the trackpad.
Because older models had this issue.
Now I am waiting for my iFixit toolkit to open the laptop and see for myself.
这个答案有帮助吗?
得分 0
2条评论:
And from my guess, it has to do with high temperature.
完成的
See if placing the system somewhere cooler and hold off charging it as well.
If you are in a humid place, place your system in an airtight bag sucking out the air before you put it the fridge if that's the best you can do.
Did that help?
完成的
添加一条评论
添加你的答案
Ivan Škorić 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 10
总计 1,831
