跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2266 个问题 查看全部
iPhone id disabled, connect to itunes
My iphone is disabled and message coming up on screen is iphone is disabled, connect with itunes.
Is there anyway to backup my phone. I know my correct passcode.
Also when i am connecting my phone to PC, phone is not getting recognized.
Please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Sorry to hear you’re locked out. To confirm, your phone says “iPhone disabled” right? There is some advice I can provide, but I’m not sure you’ll like it.
Once disabled, you either need to wait for the count down timer to complete and enter the correct passcode, or erase and restore the device.
If the iPhone has not been synced to this PC before, you will not be able to back it up either. Hopefully there will be an iCloud backup that will have been made before it was disabled.
You can review the full steps to erase the device in iTunes here: https://support.apple.com/kb/HT204306
You said the phone isn’t recognised in iTunes. You can update iTunes from https://www.apple.com/itunes and if needed, you can remove and reinstall the full software by following the steps here: https://support.apple.com/kb/HT204275
这个答案有帮助吗?
得分 0
2条评论:
Hey,
I am not getting option to re-enter my passcode. Message showing up on phone is iphone is disabled, connect to itunes.
My phone is not backed up earlier too and there is no backup on iclouds too.
I know my passcode , is there any way to backup data ?
Thanks
完成的
That is a sticky one.
If the phone has previously synced with a computer, you can connect the phone to that computer to make a backup (https://support.apple.com/kb/HT203977).
If you do not have access to a computer that previously synced, your only option is to erase and setup as new (https://support.apple.com/kb/HT204306). That will remove ant data I’m afraid.
完成的
添加一条评论
Hello Ratika
Put the iPhone in DFU mode and then remove it in that way with programs like U3tool? Only an idea that may not work.
The other option would be to update the terminal. In some occasion that has solved this problem, but if it does not recognize it is more difficult ...
Luck
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ratika Gulati 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 91
