跳转到主内容
加入维修社区 - 创建账户
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
This is a special case...
I did a hard drive replacement on this iMac about a month ago. Have not used it for about a month. Today when I try to boot it up it beeps like it has no or bad RAM. I tried new RAM sticks to no avail, still beeping like it has bad RAM.
While removing the screen to replace the HDD, the vertical sync cable came out damaged. I did my best to put it back in. Would a damaged vertical sync cable be causing this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Is there a pattern to the beeps? Did you address the hard drive thermal issue if you changed brands of hard drives?
What are the diagnostic LEDS telling you?
完成的
添加一条评论
2个答案
已选择的解决方案
I actually just solved my problem. I looted a display from an identical iMac that had suffered a fall and broke it’s foot (ouch!) and plugged it into the problematic iMac and it booted just fine. It was indeed the cable after all. @my64pro @mayer thanks for stopping by!
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
It could be possible that this is why it does not work,the computer maybe detects that the LCD is not connected due to the cable being damaged. I recommend replacing it and see if that fixes the problem.
这个答案有帮助吗?
得分 1
5条评论:
I don’t think the vertical sync cable itself is replaceable. I think I am going to have to replace the entire display which is not economically worth it.
完成的
You can replace the cable to the display,they sell the cables online.
完成的
Where are these cables sold and how do I replace them?
完成的
Looking on google,the price of these are very cheap
https://www.google.com/search?q=vertical...
完成的
@my64pro Thanks for the link, however I have solved my problem. Thanks for stopping by anyways!
完成的
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 13
总计 258
