跳转到主内容
Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
312 个问题 查看全部
How do I clone the MacBook Air hard drive?
I want to upgrade our Macbook Air original A1237 80GB hard drive to 120GB. I have Superduper and a 2 1/2" (I think that's the size) hard drive cover I've used when I upgraded our 2 iBooks to clone the new drives. I haven't got the new 120GB ATA drive for the Air but I'm afraid it won't fit.
Is there an external cover for the 1.8" Air ATA drives that I can purchase, and if so, where do you recommend?
If not, how would I clone the original drive to the new? I've got an USB external hard drive. If I clone to that how do I then clone to the new 120GB drive?
I also asked Shirtpocket what they recommend using Superduper. I'll post whatever they recommend. Thank you.
I know the Air upgrade will be harder than the iBook but I'm confident with the ifixit step by step and your help I can do it.
Thank you.
Mark
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Simple, although it took a couple of minutes to think of it. Use Time Machine to back up the drive to any external. Install the new drive. Start up from your system installation disk, use Disk Utilities to format the new drive. Now install a system and use Time Machine to move everything in.
这个答案有帮助吗?
得分 5
添加一条评论
If you want to clone the entire hard drive, here is a very good software called Carbon Copy Cloner
http://www.bombich.com. It has a trial version. I like it much better then Time Machine because your cloned drive is bootable in case of emergency. :)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mark Wynn 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 6
总计 6,042
