跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Is nondestructively replacing iPhone 7 home button glass possible?
Anyone know if there’s a way to nondestructively replace only the glass circle (roundlet, surface, whatever you want to call it) on the iPhone 7 home button? This would be for the purposes of modding the colour of the button in order for it to match a black display installed on the silver variant of the phone. Incidentally, anyone know of someone who has successfully pulled off this colour swap? Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Ive done it using heat and OEM button. First attempt to use glass only from ebay was unsuccessful. Touch didint worked. So ive used spare button as a donnor . And regarding adhesive- UV curable same as you wold be using for digitiser only repair
这个答案有帮助吗?
得分 0
1条评论:
Okay, interesting. If I do this, I would probably get a sacrificial button to try that on first. Any specific tips though? Or a link to a schematic or teardown of the button assembly? Would be great to know what's under the glass so I know how gentle to be/where to pry if necessary.
完成的
添加一条评论
添加你的答案
InternetDenizen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 52
