跳转到主内容
加入维修社区 - 创建账户
Gigabyte P34G 发布于 2013 年 9 月,是一款 14 英寸游戏笔记本电脑,搭载第四代 Intel® Core™ i7-4700HQ 处理器(2.4GHz-3.4GHz)。
Battery replacement doesn't work
With new battery replacement the icon indicate 100% full charge and when i unplug the charger the pc shutdown!
My charger specification is : output 19.5V ; 7.7A
My battery specification is : Battery Volt: 10.8/11.1V / Battery Capacity: 4300mAh/47.73Wh
My PC is : P34GV2
I buy it here:
http://www.laptop-battery.us/gncc30-giga...
This is the second battery replacement i do because the first was doing the same thing and it was returned
How its possible and what can i do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hello,
now the situation has change…
I have two os in my laptop linux and windows. The first test i do it was to test with my principal os Linux and the result is my first message here.
So i tried to test it on windows and on it, the battery work good with a good charge and discharge ect, but when i boot in linux the laptop won’t boot or run without ac charger and when i unplugged it the, os poweroff suddendly…and the same happen with a live cd.
I don’t understand where is the problem, if is the battery a lot exotical discount fabrication and also that explain the poor compatibility? or there is parameter in bios or others things that i don’t know?…
由完成的 分享
添加一条评论
3个答案
“With new battery replacement the icon indicate 100% full charge and when i unplug the charger the pc shutdown!”
2 reasons why you may be experiencing this issue:
  1. both the batteries you purchased my have been faulty.
  2. there is an issue with the motherboard getting power from the battery.
Possible solutions:
  1. replace battery again, if that doesn’t work then
  2. repair the motherboard (although sourcing information and parts may be difficult) or
  3. replace the motherboard
这个答案有帮助吗?
得分 0
1条评论:
Hello,
由完成的 分享
添加一条评论
your must buy a defective item,for your Gigabyte P34GV2 battery please look at our link:
http://www.laptopower.com/GNC-C30?search...
we have 1 year warranty
thanks
这个答案有帮助吗?
得分 0
添加一条评论
If it has one, disconnect the power button board and/or the charging port board, clean the contacts and then reconnect it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ki Ko 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 33
总计 678
