跳转到主内容
Released in 2006, identified by model number PP20L for e1505
16 个问题 查看全部
Screen goes Dark + Replaced Inverter and Backlight Already
The screen on my laptop would sometimes go dark and I could see the ghost images. It was happening for a couple of months. I was getting around this by switching to sleep mode and back which seemed to do the trick. Recently, the screen wouldn't light up at all, so for the moment I am using an external screen which worked. I did some research and the problem seemed to either be the inverter or the backlight. I replaced the inverter first which didn't seem to make any difference, then I replaced the backlight. It sometimes works and other times does not, switching to sleep mode and back seems to work now. However I'm sure it will stop working again. I'm thinking now it could be the inverter cables. Is it worth the hassle to replace this aswell? It would nearly have been cheaper to replace the whole screen at this point. Whats your advice?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Dear Gary,
could you tell me where I can find the repair guide you used to repair the converter of your Dell Inspirion 6400?
Thanks & Best regards
Tobias
完成的
Tobias Pfanner, Sorry I am not Gary, but Gary hasn't been here for almost a year. Have you tried to check on here http://support.dell.com/support/edocs/SY... ;-) ?
完成的
Dear oldturkey03,
thanks for your fast answer!
完成的
添加一条评论
2个答案
已选择的解决方案
Solved the problem.
I took out the new inverter I put in an replaced it with the old one. Bam it works perfectly. Turns out the new one was faulty!
Thanks,
Gary.
这个答案有帮助吗?
得分 3
2条评论:
The same happened to me AFTER a the inverter was exchanged: Cause: The cable connection to the inverer was not fixed...
完成的
Hola mi laptop tiene pantalla negra se ve muy pokito k puedo Aser será un cable del screem
完成的
添加一条评论
最有帮助的答案
I would Definitely replace the inverter cables before doing anything else, but first check their connections to the board and the logic board.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Gary 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 8,071
