跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
Why can't I hear out of my headphones?
So i’ve had this problem for a while now. And have done my research so far nothing has helped.
Basically one day I wanted to listen to music and put headphones on and they were plugged in but the music would only come out of the phone and no the headphones and when I record videos with my phone it doesn’t sound. I’m not sure what is the problem. And the headphones are good. I checked on other devices. Just not on my phone
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If the headphones have been tested, then the next step is the Lightning port. It’s relatively easy to try a new Lightning port, you don’t even have to remove the old one to test it. Just disconnect the old one (battery first!), then overlay the replacement one, reconnect the battery and then test the headphones again. Check out this guide for details on how to open up the phone and (eventually) replace the Lightning Port completely if necessary.
If that doesn’t solve you’re problem, then a logic board issue is the likely culprit, in which case you’d want to have this looked at by a micro-solderer. The iPhone 7 is prone to audio related issues caused by a weak copper trace on the logic board.
这个答案有帮助吗?
得分 2
添加一条评论
hi mate try this and let me know
Go to Settings > Sounds and drag the Ringer And Alerts slider to turn the volume up. If you hear sound from the speaker, follow the rest of these steps. If you can't hear sound from the speaker, contact Apple Support. If your device has a Ring/Silent switch, make sure it's set to ring
ps sometimes turning it off and on can help
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Elizabeth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 106
