跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
487 个问题 查看全部
Can you test an LCD display to make sure its broken?
The phone was dropped and cracked the front screen. I can get a red light when it charges, and sometimes a blue light will appear but it looks like its pulsing very slowly. Apart from that it will not boot up at all.
Checked the battery with a multimeter and its seems fine, also the charging port sees to be doing its job OK.
Thank you in advance for any help you can give me :-)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
hi, yes you can, however to remove the chance of another part causing the issue you will need another device that is the same. Once you have done this, follow the replace screen guide until step 14 ( 三星盖乐世S6的屏幕更换 )
then disconnect the screen ribbon, using the test display cable ( Galaxy S6 Edge/S6 Edge+/S7 Edge/Note5 Test Cable for Display Assembly ) check if the display works.
Galaxy S6 Edge/S6 Edge+/S7 Edge/Note5 Test Cable for Display Assembly图片
产品
$9.99
这个答案有帮助吗?
得分 3
2条评论:
Ahh, what a great idea. Now i just need to find another phone, its a shame it cannot be tested on its own...... Thank you so much for your help, this is such a great site :-)
完成的
no problem at all, If the screen wornt turn on then you will need another phone to test if the screen is dead, either thatr or a super cheap test screen from Ebay
完成的
添加一条评论
添加你的答案
Paul Allen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 311
