跳转到主内容
Repair information for standalone freezers.
193 个问题 查看全部
How do I replace the handle on a freezer/evaporator compartment
I have just replaced the handle on the interior freezer/evaporator compartment of a LEC refridgerator. I had to use brute force and slightly damaged some brackets.
How should I have done this properly? Is there some tool that would help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The best way to fit the door handle was first to remove the evaporator door. Then remove the broken handle and the catch fitting. This can be done with a pull on the handle to remove the male part from the female part. Next fit the new handle to the original catch by inserting the handle the top of the catch then pushing the lower open part into the catch. With a little prising the handle /catch fitting can be inserting into the door housing. Refit the door.
这个答案有帮助吗?
得分 3
1条评论:
This is pretty much what I did. But it is far from easy and I couldn't avoid minor damage. I needed to use very considerable force to get the new handle back in place.
完成的
添加一条评论
添加你的答案
Querty 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 94
总计 3,274
