跳转到主内容
该机型使用非 Unibody 一体成型机身,使用 Core Duo 及 Core 2 Duo 处理器。
MBP won't turn on/boot up
MacBook Pro 17" Model A1261
Having the same problem as other post "MBP won't turn on/boot up" . MBP was working fine, closed lid, couple hours later opened lid, unit would not turn on. I bought it used about a year ago and it has worked fine and nothing has been changed.
Power cord light is green, battery has full charge. When power button is pushed, LED light turns on for about 3 seconds, then turns off. If power button is held down, LED light stays on for about 6 seconds, flashes a number of times , then goes off. The DVD clicks a number of times and the fans turn on during this time.
I tried disconnecting the power and battery and holding the power button for 30 sec, reconnecting power-no change, PRAM reset- no change, disconnected the hard drive and DVD with no change, LED light still only comes on for a few seconds,unit will not turn on. Any suggestions what to check next? Bad logic board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
I would check your RAM. When the light on the front blinks it sometimes means your RAM modules aren't seated properly. Take out the RAM cards (make sure to wear a static wrist strap or touch something metal that is grounded before you touch the RAM! Electrostatic discharge will kill your RAM). They are located next to your battery. Here's instructions on how to do this: MacBook Pro 17" Models A1151 A1212 A1229 and A1261 RAM Replacement
Make sure the RAM cards are clean and then put them back in properly. I hope that is all that's wrong!
-LT
这个答案有帮助吗?
得分 3
1条评论:
+ nice answer
完成的
添加一条评论
最有帮助的答案
Try removing the battery and starting. Next disconnect the battery and see how far it will boot, if it goes further then insert the installation DVD, hold down the "C" key and restart. Let us know your results.
这个答案有帮助吗?
得分 4
7条评论:
I tried removing the battery and there was no change, unit will still only turn on for about 3 seconds.
完成的
Disconnect the hard drive and if that does it.
完成的
I disconnected the hard drive, no change .
I disconnected the DVD, no change.
I tried holding down the Command-Option-P-R keys while pushing the start button , no change.
完成的
Did you get a tone when trying to reset the PRAM?
完成的
No tone or chime, only sounds were the two fans running for a brief time and a few clicks from the DVD (nothing was in the DVD).
完成的
显示更多的2条评论
添加一条评论
添加你的答案
aldo mazzella 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,731
