跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
How do I straighten the chassis entirely?
My aluminum chassis on my iPhone SE bent at close to a 22° Angle from the bottom side of the volume down button clear across to the top of the SIM tray, and it’s torn the bezel of the screen away from the interior of the chassis at the top of my phone, and partially at the bottom, WITHOUT breaking my screen at ALL (miraculously) and I was wanting to know if anyone knew how to bend that chassis back into shape right, or knew where I could just buy a replacement chassis? If anyone needs them, I actually have pictures of how it bent so people can see what I’m looking at, and are willing to share them as necessary
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If you want to straighten out the chassis, it’s important to remove everything inside the device. You would need to do this also for a replacement housing so check out this guide (it’s the 5S but very similar).
Then you lean the housing against a flat surface and bend it back into shape. It’s all trial and error and if you apply too much force, you could break the housing but at this point, you don’t have much to lose. If it doesn’t work out, you can always get a replacement housing on eBay or most reputable vendors.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Christopher Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 16
总计 1,455
