跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 个问题 查看全部
Can I replace the 1.3Ghz logic board with the 1.7Ghz logic board
Hi Guys
Can I replace the 1.3Ghz logic board with the 1.7Ghz logic board? Apart from the installation is there anything else I need to consider?
MacBook Air 13” Mid 2013
Thanks for your help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Sure! Its possible, but given the fact Apple might be rolling out a newer version at the end of the month you might want to wait until you see what Apple brings out.
Here’s the part: MacBook Air 13" (Mid 2013-Early 2014) 1.7 GHz Logic Board (Apple P/N 661-7479) you really want the 8 GB board which is $460 and here’s the guide MacBook Air 13" Mid 2013 Logic Board Replacement
MacBook Air 13" (Mid 2013-Early 2014) 1.7 GHz Logic Board图片
产品
$299.99
这个答案有帮助吗?
得分 2
6条评论:
Here's a known-trustworthy site that is actually selling this model logic board. However it is only available in "refurbished, used" condition in 4 GB of RAM. All the other ones are sold out.
https://www.powerbookmedic.com/MacBook-A...
完成的
@ajcooke01 Mike will be out for a week, I go in the hospital Monday for a Cardioversion, don't know how long I will be out. So if you find answers that you can vote on, please do so as Mike and I do about 70% of the voting.
完成的
@mayer Yes sir! I will pray everything goes according as planned for you.
完成的
@ajcooke01 pretty simple procedure. You disconnect the battery and totally shut down the machine. Then ZAP the PRAM and hope you get a reboot. Really it's just a shutdown and then shock to get it restarted and hope it self corrects the electrical signals to the heart. Supposed to correct atrial fibrillation if it works.
完成的
@mayer - If its long stay we should send something to cheer him up!
完成的
显示更多的1条评论
添加一条评论
make sure your external hardware like display screen, battery compatible with 1.7 ghz logic board.
这个答案有帮助吗?
得分 0
1条评论:
Not an issue here! Apple offers multiple versions of the exact same system within the series. Only the CPU's clocking is different as in this case.
If Jack was jumping between different series then you would hit issues. Most of the time it's not the external ports ability, but the physical location and the internal connections and the boards mounting.
完成的
添加一条评论
添加你的答案
jack fuller 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 86
