跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
iPhone X Front Camera Module Flex Transfer
I accidentally ripped a flex on the front camera module. I managed to get the flex unsoldered from the sensor. I plan to order a new front camera module and transfer the flex from it. I don't know if it's been done or attempted, but wish me luck.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I wish you the best of luck with the repair! I believe this might be possible but time will tell if it actually is.
完成的
添加一条评论
1个答案
已选择的解决方案
Use low heat and don’t overdo it with the flux as you don’t want it going into the actual camera. I would also practice on a few dead flexes (from less expensive parts) if you haven’t worked on flexes before.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Brandon Desselle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 269
